916h Allis
Dennis
04-05-2003 08:13:40
I have a 716 hydro with a bad engine and a 916 with a bad gear box. Can the engine from the 916 be put in the 716?
Kent
04-05-2003 09:50:34
 Re: 916h Allis in reply to Dennis, 04-05-2003 08:13:40
Assuming both have the single-cylinder Kohlers, it should bolt right in with no changes. Some of the earliest 716s had a Briggs engine which means a different ignition and wiring system. Still a pretty simple change....
The site below may be valuable.
Gary H.
04-05-2003 09:19:09
No problem switching engines. Uses the same gearbox. You can switch whichever way you want
