Cub Cadet ??????????
Steve Gage
04-06-2003 15:44:33
I just got a cub Cadet and i don't know a thing about it.Would like to know the year, model number. Mostly the model number. It has a 10 hp Kohler, K241AS Serial # on the transmission is 385058 Ser# on motor 0237941 Spec#46329D If anyone can identify this it sure would be appreciated. thanks.
Jaybird
04-07-2003 09:27:19
 Re: Cub Cadet ?????????? in reply to Steve Gage, 04-06-2003 15:44:33
if it is a manual trans, it is either a 106 or 107.
if it is a hydrostatic trans, it is a 147 hydro
Jim S.
04-08-2003 09:46:12
 Re: Re: Cub Cadet ?????????? in reply to Jaybird, 04-07-2003 09:27:19
Hey just for the record, on 3-digit IH Cub Cadet model numbers, the first 2 digits are the hp, the third is the drive. If even, it is a gear drive. If odd, a hydro. So for example, a 106 is a 10 hp gear drive, 107 is a 10 hp hydro.
A 147 is a 14 hp hydro.
125 Hydro
04-06-2003 18:18:16
Link
Hi, Steve: Okay let's begin with the site that I just posted. If you go to their technical information site there will be a wealth of info about serial number location(s) on Cub Cadets. The 38.... number has R1 after it. This is the casting number of that particular part. Your engine will tell a lot about the engine however someone may have changed engines. I reccomend this site as a beginning in your journey to find out more about your Cub Cadet. I am assuming that there is no model number on the hood and even if there were sometimes hoods have been put on from other models. Your overall design will be the most help. This is where the site I listed will have info on the serial number location. Here is also one more site with some more info on serial number breakdown.
http://www.ihcubcadet.com/
Steve Gage
04-07-2003 12:50:24
 Re: Re: Cub Cadet ?????????? in reply to 125 Hydro , 04-06-2003 18:18:16
Thanks a bunch guys! Really Appreciated. Steve
