Electrical problem on Wheelhorse 8-312
Mac/MS
04-07-2003 07:24:32
Just put new short block on and hooked everything back up wasy I took off. Turn the switch on to start nothing happen. Can jump across and make starter spin but didn't engage. Any ideas as to what is wrong?
William Pearson
04-08-2003 18:55:18
 Re: Electrical problem on Wheelhorse 8-312 in reply to Mac/MS, 04-07-2003 07:24:32
Sounds like two problems .
1) The trigger wire to the solenoid is not getting current . Check the wires from the ignition switch to the soleniod for being cut.
2) The starter bendix needs to be cleaned . Move the starter gear back and forth a few times .
Also make sure all the ground connections are clean .
Bill in Richmond , Va.
