David bradley walk behind
Seth
04-12-2003 12:08:58
I have a David Bradley Walk behind garden tractor and was thnking about putting dual wheels on it. Does anyone out there know if this can be done, and if so what do i need to do it with. Any pictures would be very helpful. Thanks for your help. Seth.
Brian G. NY
04-13-2003 06:15:24
 Re: david bradley walk behind in reply to Seth, 04-12-2003 12:08:58
The easiest way is to take a piece of 2" X 3/16" band iron and make a ring just large enuf to fit within the bead "lip" of the wheel. Then put the 2nd wheel up against the first and run bolts thru the weight mounting holes. The ring dia. will be close to the nominal dia. of the wheel.
