Briggs Stratton
RH
04-15-2003 05:52:52
I've replaced the 12.5 engine which had a broken rod with a 12 hp. The original engine had two wires and a connector attached coming from under the flywheel. The replacement engine doesnt have these. Is there a solution for this. Any help appreciated..
Sirmowalot
04-19-2003 21:24:51
 Re: Briggs Stratton in reply to RH, 04-15-2003 05:52:52
Are there any wires coming from under the flywheel? If there aren't you don't have an alternator in you engine thus your battery won't charge. Some of the briggs had a single wire alternator. If that is what you have you might want to consider swapping the alternator and / or flywheel if it is possible.
