Briggs Straton choke
Brad
04-17-2003 20:50:27
I have an 18 hp briggs & straton in my craftsman lawn tractor. The only way I can get it started, and keep it running, is to completely close the choke AND cover the small hole in the choke itself. If I let up on the hole the engine starts to die but will keep running if I once again cover the hole. I've changed all of the normal stuff - fuel filter, plugs, etc. Even overhauled the fuel "pump", adjusted all the available screws, mixture, idle, etc. but it no success. ANY IDEAS? Help!
Charles
07-04-2003 02:41:59
 Re: Briggs Straton choke in reply to Brad, 04-17-2003 20:50:27
Check the throttle shaft for looseness within the carburetor. If there is loseness, you are sucking in air and the throttle shaft needs to replaced.
MJM
04-19-2003 13:43:39
You will need to rebuild the carb. The jets are stopped up.
MJM.
tlak
04-18-2003 05:12:19
Usually if you have to close the choke that much its getting air from some where else to run. Check for vacuum leaks.
