Briggs and straton engine will not spark
jeremy
04-18-2003 15:10:14
I have a late seventies briggs and straton engine on a tiller i just replaced the magneto or coil the points and condensor before that I would turn the engine over with my hand holding the plug wire and I would not get shocked. After replacing everything from above I am getting a pretty good shock from the plug wire after turning over the engine but I cannot find a plug not even a new one to produce a spark.
Jake_1234
10-15-2004 17:24:53
 Re: briggs and straton engine will not spark in reply to jeremy, 04-18-2003 15:10:14
The gap between the Coil and flywheel should be about the size of a note card ,and check the connection to the end of the plug.
Chris D
09-22-2004 08:19:47
I have the same problem, I'm getting a hugh shock but no spark? Any help welcome at dugardchris@aol.com Thanks
Mark V
09-08-2003 17:01:14
i HAVE THE SAME PROBLEM AND YES I AM HOLDING THE PLUG AGAINST THE BLOCK (METAL). I SET THE PLUG GAP, THE POINTS GAP AND THE FLY WHEEL GAP PROPERLY. I GET A SHOCK FROM THE PLUG WIRE BUT SEE NO SPARK FROM PLUG. HELP
Sirmowalot
04-19-2003 21:07:42
Are you holding the plug against the block? The plug will not spark unless it is grounded.
