Fixing plastic body
John
04-19-2003 07:44:53
I have several cracks in the plastic body on an old jacobsen homelite 42 inch mower. Can any one help on the type of glue to use. glueing unknown plastic seems to be either epoxy or Krazy glue
Thanks
Jim
04-25-2003 15:12:37
 Re: fixing plastic body in reply to John, 04-19-2003 07:44:53
Housings on garden equipment are often ABS, or an ABS/styrene blend. Hope that helps.
Sirmowalot
04-19-2003 21:06:21
If you happen to have a friend in the auto body repair business give him a crack (no pun intended) at it. Most auto body shops have the tools to fix plastics (since most cars are now 50% plastic).
Jody hymel
04-20-2003 20:10:25
 Re: Re: fixing plastic body in reply to Sirmowalot, 04-19-2003 21:06:21
Call around and see if anybody does plastic welding they have a place not to far from me that does it.Call a place that sells plastic they will tell you if their is a place that does it local. If not harbor freight sells a small plastic welder for like $39.
Jody
