786 cub engine swap
Michael Spenneb
04-21-2003 20:42:02
I have a 1982 786 cub with the KT17 kohler motor. I believe it is the model with the spray lube system and i would like to replace the old motor with something better, maybe even some more horsepower. I've found a 18 horse kohler part# 24646-M18QS with the same 1-1/8" shaft size , and was curious if this would bolt up to the tractor and use the same wiring harness without any modifications or is there another alterative to my tired engine. I also like that the 18 horse has a full pressurized lube system which I feel I need considering my mowing conditions. (lots of hills)
Larry415
05-03-2005 06:33:09
 Re: 786 cub engine swap in reply to Michael Spenneberg, 04-21-2003 20:42:02
I believe the 18 HP Kohler Magnum engine will bolt up if it has the cub cadet modification, but the wiring will need some medications. I have one in mine and it work fine. I put an oil pressure gauge on mine.
