Adjusting PTO Clutch on Bolen 1700 Eliminator (5017H)
Ben Held
04-22-2003 05:48:03
I have a Bolens 1700 Eliminator with the Kohler QT17 motor. I just replaced the engine seal on the front of the tractor. Does anyone know how to adjust the PTO clutch? There are four bolts with springs under the nuts that can be adjusted to set the clutch tension.
I have it together and adjusted to somewhere I thought reasonable, but I hear a metal on metal rubbing when I run it. Help!
mt
04-22-2003 18:07:32
 Re: Adjusting PTO Clutch on Bolen 1700 Eliminator (5017H) in reply to Ben Held, 04-22-2003 05:48:03
you need .010 to .014 air gap slots for checking work your way around g/l tim
