williemon
04-23-2003 18:30:14
This is on a Murry riding mower. Last weekend, mower fired up. Battery is weak, although it is only about a year old. May be low on water or just dirty. Had to boost it with my portable, rechargeable battery jumper. Done that several times in the past 4 months. Was going to perform a long , overdue maintanance checkup in a few weeks. Had to replace start switch about 2 months ago. Been running fine with the exception of the weak battery. When I went to shut off the engine last weekend after I had finished, I dropped it to idle and it quit. I thought nothing of it since it has done that before from time to time. This weekend, the engine would turn over, but would not run. Not even a sputter or cough. Checked plug. Looked good. Grounded it to the cylinder and watched it fire. It looked good to. It was dry though, like it had no gas. Put it back in, ground down on the starter with it choked for a bit. Checked plug. Again it was dry. I had gas, and it was flowing into the float bowl. Pulled carb and feild cleaned it. Pulled main and idle jet, wiped them and installed them. I think I went 1.5 out on main and 2.5 on idle. Installed freash gas. Now I still get spark, plug now gets wet, but it still wont make so much as a cough. Pulled flywheel. Cleaned mag posts and flywheel magnet. No points. Has EI. Key looked like a steel key and looked good as best I could tell. I did not figure a steel key would affect timeing. Ive tried choking it to death, and cranking with it in fast, but not choked. Theres no spit, sputter or anything. Starter is saying some 4 letter words at me so I need to quit on grinding on it. So the way I see it, I have air, gas, and spark. What am I missing?? I also tried my compression guage on it. I hooked it up and cranked away. I saw about 25 to 30 psi. Valve cover has 2 screws, so I pulled it off and the valves look to be working properly. I had a mm feeler guage and at TDC on compression stroke I measure a tight .5mm and on the lower a loose .5mm What is all this supposed to measure? Thanks.
