Briggs flooding issue
Ric
05-03-2003 08:08:30
I've got an 18.5 I/C twinII which will run and cut fine for abaout 5 minutes. . . then floods-out. Restarts immediately, but appears to need to cool prior to continuing operation. just rebuilt carb. cleaned gas tank and replaced fuel. new fuel pump. new vaccuum and fuel hoses. new plugs. i THINK it's the governor / throttle settings, but have no idea what changes / settings should be.
Ollie
05-03-2003 08:18:06
 Re: Briggs flooding issue in reply to Ric, 05-03-2003 08:08:30
Any engine that runs perfectly for 5 minutes and then just dies is suffering from either...
1) Clogged vent in gas cap
2) Dying ignition coil/module
Sam S
05-04-2003 10:13:13
 Re: Re: Briggs flooding issue in reply to Ollie, 05-03-2003 08:18:06
Ric, I have had similar problems with a 14 twin and it ended up being a plugged (partially) atmophereic pressure vent and leaking float. Let us know what you find.
Good luck.
