B S 17hp I/C Twin II Oil Leak
JT
05-03-2003 20:02:40
Briggs & Straton 17hp I/C Twin II Model 42A707 Type 2653E1 Code 9903125A Murray R
ider 42" deck. The mower has run great since 99 except for backfiring most of the time when turned off. I suspected that it used a lot of oil last week but was unsure. This week I used the mower over 1 hour and it used more than 8 ounces of oil. The oil had run down the bottom left side of the motor. I removed a couple of heat sheilds and the oil seems to be coming from between the head base and the block. Could this be as simple as a bad head gasket? Any advice? The motor still runs smooth with no noise or smoke. I don't beleive it to be leaking while not in use. Help!
