Cub cadet clutch
jim
05-04-2003 12:58:04
the clutch on my 108 won't "hook up" unless I apply slight pressure to the pedal. is it worn out? any advice/info would help.
Wally G.
05-04-2003 18:01:22
 Re: cub cadet clutch in reply to jim, 05-04-2003 12:58:04
You probably have a broken pin in the coupling at the rear. When you put slight pressure on the clutch it pushes against the input shaft and will move the tractor. Drive out the pins and either get the coiled sring pin or get two 1/4" by 2" grade 8 bolts with nylock nuts and put them in..DO NOT USE REGULAR ROLL PINS!!
