3.5 hp briggs won't fire
Mr. farmer
05-04-2003 15:57:11
I have a what I think is a 3.5hp briggs and stratton that won't fire. It has a brand new spark plug so that ain't the problem.
Thanks for any help
Bus Driver
05-04-2003 18:05:09
 Re: 3.5 hp briggs won't fire in reply to Mr. farmer, 05-04-2003 15:57:11
The two most likely causes for this engine not to fire are a sheared flywheel key or a bad coil. Pull the flywheel and check the key. If sheared, be sure to use a flywheel key as replacment, not a regular steel key.
ryan
05-06-2003 07:59:44
 Re: Re: 3.5 hp briggs won't fire in reply to Bus Driver, 05-04-2003 18:05:09
What the hells the model mumber
Rusty Jones/ The Mower Man
05-11-2003 18:16:52
 Re: Re: Re: 3.5 hp briggs won't fire in reply to ryan, 05-06-2003 07:59:44
If your engine is the vertical shaft type, you can use a coil from a late model engine (vertical shaft, made in the last 5 years or so. Just cut the wires leading under the flywheel, but not the ground shutoff wire from the coil. Set the air gap to the thickness of a regulation postcard. This is the gap between the coil legs and the magnetic part of the flywheel! If you must be technical, set the gap to .010. Put it back together and it'll run until you forget to check the oil, or you shut it off manually!
