Cub Cadet Engine replacement
Pete A., rural
02-26-1999 21:11:24
Looking at an old model 73 cadet.For a everyday use tractor, is there any reason a person could not use say, a brand new 10 hp single cylinder Tecumseh in place of the old 7hp Kohler unit? ....Thanx....Pete
Mark H
02-28-1999 10:30:55
 Re: Cub Cadet Engine replacement in reply to Pete A., rural western NY, 02-26-1999 21:11:24
you can get a replacement motor from cub cadet dealer that will work but it will be 12 hp. there are a lot of good but used motor out there. If you can not find one let me know and I will give you a list of names you can contact.
Mark
Don
02-27-1999 18:27:54
Pete, If you are looking for more HP, May I suggest upgrading to a 10 or 12 HP Kohler K series. Many old Kohlers are out there in running or re-buildable condition. I frequently rebuild 10s for less then $350 using aftermarket parts. If your looking for a "new" replacement motor make sure it has a cast iron flywheel and cylinder liner. You will have to adapt the drive shaft carrier and front pto. This may be a large project if you don't have access to a machine shop. You may try contacting the Cub Cadet web page for more info on parts and conversion. Good Luck. Don
mike
03-27-1999 14:02:13
 Re: Re: Cub Cadet Engine replacement in reply to Don, 02-27-1999 18:27:54
REPLACE KOHLER WITH TECUMSEH,DONT DO IT MAN!!!
INFO,FEEL FREE TO E-MAIL ME.
