1541 Cub Cadet has fuel pump problem
Bob May
05-05-2003 17:30:41
I suspect my fuel pump is faulty. I went to the dealer to get a new one. The new one does not even look close to the oridginal one. It is shaped different, has the openings in a different pattern and is all plastic. It also is made by Briggs and Straton. It is Briggs part # 808656. I asked two other dealers and both tell me it is the new replacement part. If this is true I would appreciate it if some one could tell me which connection gets which hose.
Any and all help appreciated.
Bob May
dave stearns
05-06-2003 20:02:58
 Re: 1541 Cub Cadet has fuel pump problem in reply to Bob May, 05-05-2003 17:30:41
should be a vacume pump. the line from your vacume source wil go to the port centered in the pump. It is a diaphram and they are usually the same. The fuel line should hook up on the side or edge.
