Cub Cadet 1420 Hydro problem
Drew
05-08-2003 15:58:07
I am experiencing a problem with my tractor whereby it will not move. The belt is fairly new the pulley seems to move and the key is not broke on the drive pulley. I removed the drive pulley and all the gears appear to be ok. There is a shaft that is sticking out of the casing directly across from the pulley that does not move when you try to engage the tranny. The fluid is up; the fluid does not show any signs of metal and is clean. The tractor seemed to be working fine, I went into reverse then tried to go forward and it stopped. The tranny does not seem to get hot at all? Any thoughts.
