BS 12 hp Will not start just backfires.
Paul
05-09-2003 18:24:49
Had the mower running for a couple of hours then shut it off. Cranks over and has a spark. All I get is a backfire coming out of the carb. Any suggestions would help. Thanks.
bill
05-10-2003 02:09:37
 Re: BS 12 hp Will not start just backfires. in reply to Paul, 05-09-2003 18:24:49
I am having the same problem. mine is on a cub cadet. there are two screws on the carb that I can't seem to get adjusted. you might try turning these but be careful, a lttle too much and you will be way off
Ben in KY
05-09-2003 18:29:52
Flywheel key sheared ? Valve stuck open ?
couple of ideas there.
