Cub 184 won't start
Jim in Oberlin
05-10-2003 19:16:59
I've an International Cub lowbow 184. I've pulled the plugs individualy leaving them hooked up to the distributor to check for spark. All have spark. I've ck'd the gap on them, and on the points. It's getting gas. What next?Compression?It ran last week, though sluggish sometimes. Last summer when using it,( it's only a mower, no P.T.O.), while the tractor was running,you could not engage the mower. It would stall out. I always started the tractor with the mower engaged to avoid the trouble.
Sirmowalot
05-11-2003 22:46:36
 Re: Cub 184 won't start in reply to Jim in Oberlin, 05-10-2003 19:16:59
I would check the valve clearance. If you have a valve that is tight it would cause the condition you are describing.
Jim in Oberlin
05-12-2003 12:37:12
 Re: Re: Cub 184 won't start in reply to Sirmowalot, 05-11-2003 22:46:36
Sirmowalot,i hear what your saying.The engine does turn over but it just dosen't seem to want to fire.I haven't taken the engine apart.
