12HP Briggs IC Valve seat??
Brian
05-10-2003 21:43:48
I have a 92, 12 HP Briggs, Always ran good, and changed the oil but today no compression?? Intake Valve seat came out and held the valve open. Beside short blocking it what should I do??? Motor is to good to throw out...
Brian Gnagey
05-17-2003 20:27:19
 Re: 12HP Briggs IC Valve seat?? in reply to Brian, 05-10-2003 21:43:48
Thanks for the tips!!!! I also did some asking around and this is a few more tips, Clean out the seat and JB weld it and also stake it. Then here is one I like take the seat and grind a bevel on the outer top part then stake it in. It gives a little more metal to hold the seat in place!! Thanks Brian
JOHN HELMS
06-19-2004 18:34:01
 Re: Re: 12HP Briggs IC Valve seat?? in reply to Brian Gnagey, 05-17-2003 20:27:19
YOU DON'T NEED TO JB WELD IT. STICK THE VAVLE SEAT BACK IN. THEN SCORE THE OUTSIDE OF THE VALVE SEAT WITH A PUNCH. THIS WILL HOLD IT IN PLACE. AND PUT IT BACK TOGETHER.DONE THIS SAME REPAIR MYSELF. TRUST ME IT WORKS.
buck
05-10-2003 22:04:44
I have run into this situation several times in the past and with everything considered I just put the seat back in place and with a sharp punch (center punch) I punch around the seat bringing the block material tight against the seat.I have had varied results. Don't forget to check and reset the valve stem gap.Note: some good small engine shops can fit an oversize seat.
Sirmowalot
05-11-2003 22:44:02
 Re: Re: 12HP Briggs IC Valve seat?? in reply to buck, 05-10-2003 22:04:44
I agree with buck. If you aren't sure of what you are doing you would probably be money ahead to take it to a machine shop and let them fix it. No sense in messing up an otherwise good engine with a slip of a hammer & punch.
