Craftsman lawn tractor help
greg
05-11-2003 09:19:46
Hello, the other day I was mowing grass and my lawn tractor just stopped. The engine will turn but no spark. Carburator getting plenty of fuel. Replaced spark plug wires and the thing that they are attatched to. still no spark. Engins turns. what could be wrong?? Where can I get a schmatic for the electrical system. Greg
ALIVE GIVENS
06-20-2003 17:11:26
 Re: craftsman lawn tractor help in reply to greg, 05-11-2003 09:19:46
MY CRAFTSMAN LAWN TRACTOR MODEL 917.272121 HAS A PROBLEM BREAKING THE MAIN DRIVE BELTS. I HAVE REPLACED THIS BELT 6 TIMES ION 4 YEARS. MY QUESTION IS" IS THERE A HEAVY DUTY BELT AVAILABLE FOR THIS TRACTOR." PART NO. LISTED IS 139573.
JIM
05-11-2003 10:04:02
THE MOTOR COULD BE OUT OF TIME IT COULD HAVE A SHEARED KEY WAY OR THE MAGNEAT IS NOT SET QITE RITE IF YOU REPLACE THE MAGNETO YOU MAY ALSO HAVE A GROUND PROBLEM. BUT IF YOU HIT SOMTHING WILE MOWING I WOULD THINK YOU HAVE A SHEARD KEY WAY
Greg
05-11-2003 16:14:49
 Re: Re: craftsman lawn tractor help in reply to JIM, 05-11-2003 10:04:02
Thanks Jim, I did no hit anythingandI did replace the magneto. I tried to set it as best I could with my feeler gauges but maybe I should try again. do you think that it could be the clutch kill switch or seat kill switch?
Ben in KY
05-11-2003 18:48:53
 Re: Re: Re: craftsman lawn tractor help in reply to Greg, 05-11-2003 16:14:49
I would suspect one of the safety interlock switches.
charles parsos
05-14-2003 21:52:32
 Re: Re: Re: Re: craftsman lawn tractor help in reply to Ben in KY, 05-11-2003 18:48:53
Had the sam problem with my dt200 craftsman mower.
Replace the ignition wiring assembly and that fixed the problem.
Would just die...no ryme resaon or song
Hope this helps
