16 hp kohler help
ray
05-13-2003 04:14:08
I have a 16 hp kohler eng. it has gas coming out of the carb when it is running I took off carb. checked float and gas valve seems ok what could be wrong. thanks for the help
Steve
05-19-2003 17:23:27
 Re: 16 hp kohler help in reply to ray, 05-13-2003 04:14:08
Mine was doing the same thing but barely ran. It turned out to be an ungrounded condenser.
KennyW
05-13-2003 04:31:18
Replace the needle and seat and submerse the float in water to make sure you have no pinhole leaks. What model Kohler is it?
ray
05-13-2003 04:50:24
 Re: Re: 16 hp kohler help in reply to KennyW, 05-13-2003 04:31:18
kenny, dont know but it is .its on yard man mower from lowes.also what does the elect.cyl do on btm of carb
Jim S.
05-13-2003 07:15:28
 Re: Re: Re: 16 hp kohler help in reply to ray , 05-13-2003 04:50:24
If yer float is OK, then you gotta have a worn needle or a piece of dirt on the seat. Time to do a thorough fuel system cleaning and rebuild the carb. A kit is only $9-10. Be sure the float is parallel to the carb bowl base when the carb is held upside down.
The solenoid is a fuel shutoff that automatically closes down the gas flow when the engine is off. That's why gas isn't running out of it all the time.
