318 starter?
brian
05-29-2003 18:28:43
How is the best way to replace the starter in my Onan JD 318. It looks like I have to remove the engine to get at the starter. I do not have a service manual but it looks like I have to lift the engine out. Any one know?
SHANNON
06-05-2003 22:56:38
 Re: 318 starter? in reply to brian, 05-29-2003 18:28:43
FOR WEARING OUT A STARTER ON AN ONAN I CAN SAY THE ENGINE GETS A GOOD WORKOUT,OK DEPENDING ON ENGINE ORIENTATION ON TRACTOR,SOMETIMES YOU MAY JUST BE ABLE TO REMOVE ENTIRE GRILLE TO GET TO STARTER,MAYBE NOT,PLAN ON REMOVING FLYWHEEL SHROUD ALSO ON ENGINE (THIS IS THE ONLY WAY YOU CAN GET TO STARTER BOLTS)BEEN THERE/DONE THAT ON ONAN POWERPLANTS.TAKE YOUR TIME.
JDOUG
05-30-2003 05:15:19
At the very least you will have to lift the engine up out of the frame. Depending on the type of starter on your engine you have to also remove the flywheel to get to the starter bolts. The solenoid shift type starter has the bolts going from the starter side into the engine. The bendix type starter has the bolts coming from the flywheel side into the starter.
