Carb adjustment on 16hp Roper tractor
Bob S.
05-30-2003 14:18:21
Hi,
Alright, we've got a 16hp roper lawn tractor that is not running well. In late fall I rebuilt the carb, replaced all gas lines, flushed the gas tank, etc. It seemed fine at the time. Now I'm not getting full power, and to keep it running I need to have the choke 1/3 to 1/2 on. Do I need to open up the hi speed needle more?
--Bob
bruce
06-30-2003 19:48:50
 Re: Carb adjustment on 16hp Roper tractor in reply to Bob S., 05-30-2003 14:18:21
if you need to run your choke at all to keep it running you still have a blockage in the carb,try to clean it with a soak cleaner from auto zone and try to blow it out good.
