Ford lgt 145
jap
05-31-2003 11:24:59
help I have a ford lgt 145 and need imfo. on how the mowerdeck is mounted.I can not find anything .thanks
Scott
09-02-2003 20:21:12
 Re: ford lgt 145 in reply to jap, 05-31-2003 11:24:59
I have an original manual for the 50" deck and how it goes on. I can scan and send if you think it would help.
Cam
08-18-2003 14:41:47
The 42 inch deck lifting frame was connected with four shoulder bolts and bronze bushings to the tractor main frame. There were four more bolts and bushings on the mower lift frame itself. In this way, the lift frame was a four-bar mechanism. The deck would then slide under the tractor, and roll forward and join with the lift frame. The deck would then float to account for ground conditions, when lowered enough.
