Briggs Strat problems
Adam
06-01-2003 19:29:56
I've got a 10HP B&S that starts beautifully but there's white smoke comming from the exhaust, then every 5 or 10 seconds at idle it struggles and nearly stalls for an instant, then returns to idiling normally. While it struggles the exhaust changes from white to blue. The oil level is correct, and the rings/cylinder/plug/valves are all in perfect condition; Any ideas?
RWP
06-02-2003 20:43:18
 Re: Briggs Strat problems in reply to Adam, 06-01-2003 19:29:56
Adam: Go to www.briggsandstratton.com. Type in your model number, type, and code. Briggs and Stratton has one of the best websites out there. If you don't find your problem on "frequently asked questions", you can e-mail them from the site, and they will return an answer. On this site you can view your owner's manual, you can download a parts manual, and an alternator manual, which shows you all the wiring diagrams. There is so much to view on this site. I have two Briggs and Stratton motors and I have been able to get information on both engines.
marv
06-01-2003 20:37:52
check breather also if you have dip stick check if it is sealing properly Il try to think of a couple of other things is it hill side mowing good luck
