12 Kohler in a Toro
ric
06-08-2003 06:55:06
12 hp Kohler in a Old Toro Wheel Horse..
Runs and stops..worse on real hot days when working it..
Runs great..then starts to backfire (pops)..and slow down until finally stops.. usually will restart in just a few minutes...then repeats after a few minutes of running. I have replaced the following:
points, plug, fuel filter, coil, ...starting to think it might be a sticky valve..
Anyone with any suggestions ...and how do I check for sticky valve? Any way to free a sticky valve without tear down/??
ps i got this tractor from a neighbour who left it outside summer and winter ..he had same problem had it to dealer several times without any luck..just another reason I think it could be a sticky valve...
ed
07-18-2003 12:35:49
 Re: 12 Kohler in a Toro in reply to ric, 06-08-2003 06:55:06
I have a C-120 Wheelhorse tractor 12hp ( 20 or 25 years old). I am having the same problems. When it get hot, it will cut-off or stop! After cutting, it will backfire(pop). I am thinking about having it rebuilt. Do you think, this would help. ed
bruce
06-26-2003 19:11:38
did you get it running or not? did you try the coil and i don't see it could be anything else,if it runs good until it gets hot .
bruce
06-10-2003 19:27:18
have you tried to change the coil,sometimes when a motor gets hot a bad coil will quit firing, if you have points and condenser I would suggest that you change to electronic module.
Rob T
06-10-2003 13:31:42
I agree with wboston. What you describe is a symptom of a bad condensor. Did you replace it with the point's? If not I would before you start worrying about the valves. A bad condensor will fail as it heats up, it cools a bit and starts to work again, heats up and fails again. etc. I always replace the points and condensor as a set.
Rob
ric
06-10-2003 20:12:08
 Re: Re: 12 Kohler in a Toro in reply to Rob T, 06-10-2003 13:31:42
yes i did replace condenser with the points..I also always replace them as a set...
thanks anyways...
regards ric
wboston
06-09-2003 17:31:09
Sounds to me like a condenser. did you replace it with the points?
Rick
06-08-2003 08:10:09
You can send it to me! You could try some od the chemicals that are supposed to free up valves but I think from the sound of it you may just need to adjust them.
Rick
06-08-2003 14:48:50
 Re: Re: 12 Kohler in a Toro in reply to Rick, 06-08-2003 08:10:09
In Minnesota
take the breather plate off and there is where the ajustments are made. I have to get my book back from my brother in law for the specks on the clearances.
ric
06-10-2003 20:09:15
 Re: Re: Re: 12 Kohler in a Toro in reply to Rick, 06-08-2003 14:48:50
ok ..thanks I will give that a try..
regards ric
ric
06-08-2003 09:38:22
ok where are you? Adjust the valve? how do you do that?
ric
Ron Hart
06-08-2003 15:54:54
 Re: Re: Re: 12 Kohler in a Toro in reply to ric, 06-08-2003 09:38:22
Try some Marvel Mystery Oil in the gas.
Ron
steve
07-14-2003 12:38:09
 Re: Re: Re: Re: 12 Kohler in a Toro in reply to Ron Hart, 06-08-2003 15:54:54
see if it does it with the gas cap loose, it may be developing a vacume in the tank causing fuel starving.
