Brake for Cadet 124
Mark
06-09-2003 21:44:38
Just picked up a 124 and it sounds like the brake is draging. I'm waiting on a manual. Any ideas?
Do I have to split the tractor and go inside the gear reduction.
Also the clutch pedal is very hard to push.
Are the two problems related?
dvogtvpe
06-11-2003 10:30:01
 Re: Brake for Cadet 124 in reply to Mark, 06-09-2003 21:44:38
the 2 most common problems I see are the piston siezing in the bore & the pivot pin that holds the brake lever on the front of the trans case siezing up. both can be repaired with patience while in the tractor but can be a pain.
Mark
06-10-2003 19:04:39
That helps. Thanks Gary
Gary
06-10-2003 06:24:57
Your brake disc is inside the transaxle. It is actuated by a lever connected to an assembly at the lower front of the transaxle. It is a guess that this area is frozen up and needs attention.
The clutch and brake are all on the same peddal.
Your peddal may get hard near the bottom os it's stroke. That is where the brake starts to work.
