Best price on Briggs rebuild kits? 11 horse
Uriah
06-10-2003 17:43:57
Just got a Bolens G11 (1155). Went 800 miles round trip for it. I need to do a few things to it (ah, ready to use, was it?). Mainely I have to rebuild the carb, and the engine REALLY needs some rings at the very least. It smokes like a freighttrain, but oddly enough, still has plenty of power, even for such a small engine.
Anyway, where is the best place to get a good rebuild kit for a 11 horse briggs single and the carb that's on it? Mostly, I just want a piston/rings and gaskets. I moonlight at a machine shop, so I'm not really worried about valves or anything I can machine myself.
JDK
06-12-2003 20:54:26
 Re: Best price on Briggs rebuild kits? 11 horse in reply to Uriah, 06-10-2003 17:43:57
I have found over the years that quality gasket sets vary very little in price between brands.If a given offer is much less,see what it "does not" include.Often a "set" that sells for less requires you to buy one or more extra gaskets to have eveything.
Sam
06-13-2003 20:28:09
 Re: Re: Best price on Briggs rebuild kits? 11 hors in reply to JDK, 06-12-2003 20:54:26
I don't know if you can set up an account, but you can try Sooner Distibuting at 1-800-224-4704
I see in a Stens rebuild kit .010 over including piston, gasket set, both oil seals, both valves and chrome rings for around $ 50.00 plus shipping. It is part number 785-550 and fits models 251700 thru 257700 vertical 11 h.p.
The kit in a Prime Line #7-09707 is about the same price. I need the model to get carb kit #'s.
I hope it helps. .020 under connecting rod I think is #510-069 and is about $ 28.00, standard rod is #510-065 and about $ 25.00.
