8 hp cast iron tecumseh
Roger
06-11-2003 12:25:55
the above engine appears to have exess crank case pressure.. is blowing oil out of the vent hose that connects to the air filter box and fouling the air filter. the intake valve has a rough stem and appears to be a source of oil to the top of the cylender. to top this off it backfires thru the carb. any ideas out there?..Thanks Roger
Jake
06-22-2003 19:56:19
 Re: 8 hp cast iron tecumseh in reply to Roger, 06-11-2003 12:25:55
Backfiring through the carb means either the timing is off or as MJM said, a valve job is needed.
MJM
06-11-2003 18:48:35
sounds like you may need a set of rings and a valve job.
