Flummoxed by Peerless transaxle
Bill
06-13-2003 14:23:42
I reassembled a model 730 and got 1 spd forward and 4 spds aft. I must have flopped some gear. I don't have any drawings or pictures. It never occurred to me that it would be possible to do that. Bill
BILL
06-16-2003 15:30:51
 Re: Flummoxed by Peerless transaxle in reply to Bill, 06-13-2003 14:23:42
Pulled the transaxle down and saw that the large bevel driven gear would fit up on either side of the bevel drive gear. I'm sure it is by design. Probably some applications that would require opposite rotation. Could be a handy fact to know.
By the way, I'm working on a model 930 Peerless.
BILL
dale
06-16-2003 05:19:59
been there and done that. here is what i done wrong when it happened to me.
i had put the ring gear on the wrong side of the pinion gear thus it turned backwards. 1 forward 6 reverses
SHANNON
06-14-2003 22:50:21
CHECK FINAL DRIVE(WHERE AXLE STUBS STICK OUT)MAY HAVE ON OPPOSITE SIDE OF PINION..... ..
george
06-13-2003 20:09:23
sure ya don`t have a twist in the drive belt ?
Bill
06-14-2003 08:26:47
 Re: Re: Flummoxed by Peerless transax in reply to george, 06-13-2003 20:09:23
First thing I checked!
Rick in MD
06-14-2003 11:40:33
 Re: Re: Re: Flummoxed by Peerless tra in reply to Bill, 06-14-2003 08:26:47
I beat you have the bevel gear turned around. Let me know what you found or if you have any questions.
Bill
06-15-2003 16:25:34
 Re: Re: Re: Re: Flummoxed by Peerless in reply to Rick in MD, 06-14-2003 11:40:33
I too suspect it must be the bevel gears. It just didn't look like like it could be assembled in two different ways there. Will tear down in next couple days for sure.
RAYMOND
06-17-2003 06:05:49
 Re: Re: Re: Re: Re: Flummoxed by Peer in reply to Bill, 06-15-2003 16:25:34
You can get a complete rebuild manual off the net by searching for peerless tecumseh, and looking for "motion drive" I just rebuilt mine, HOPE THIS HELPS
I am looking for a manual for the FORD YT16,as I just bought it and am having some problem with the mower deck hook up
