1650 cub cadet...spark????
Alan Kulp
06-13-2003 15:01:44
1650 cub cadet sparks when cold.... very lite spark when hot.... Coil gets warm.... any suggestions please help....grass getting real high
terry
06-16-2004 11:37:44
 Re: 1650 cub cadet...spark???? in reply to Alan Kulp, 06-13-2003 15:01:44
hi i just got my 1650 in the spring the last 2 times i mowed it shut down i had no spark then i checked the spark plug wire with a voltameter and found it had a brake in it then i replaced it and now it works fine hope you find out soon terry
SHANNON
06-15-2003 09:31:54
SHORTED COIL,REPLACE UNIT...
Alan Kulp
06-13-2003 18:45:47
ok...do you know why the coil would be getting hot?
lucas
06-13-2003 15:46:09
i would try points,condenser and points rod first. also be sure your maintaining at least 8.5 volts when running ,must have at least 8.5 for coil to fire.... lucas
Dan
06-15-2003 13:53:35
 Re: Re: 1650 cub cadet...spark???? in reply to lucas, 06-13-2003 15:46:09
Replace the coil, then check to make sure your generator is wired correctly, reversing the wires will cause the coil to heat and burn points!
KEITH
06-15-2003 19:02:02
 Re: Re: Re: 1650 cub cadet...spark???? in reply to Dan, 06-15-2003 13:53:35
I HAD THIS TROUBLE BEFORE AND MINE TURNED OUT TO BE A BAD CONDENSER GOOD LUCK!!
