Case 210 mower engagement clutch
gary potter
06-14-2003 06:07:03
Can anyone clarify the procedure in adjusting the clutch on this compact tractor. I have replaced the friction disc and put the unit back together with 3 shims under the clutch fork bearing. I don't know how to get the corect pressure to allow engagement/disengagement by the side mounted lever.
Doc
06-14-2003 06:24:30
 Re: Case 210 mower engagement clutch in reply to gary potter, 06-14-2003 06:07:03
Gary, the bearing housings have to be installed a certain direction to get the "squeeze" needed for clutch engagement. I've got a manual for the Case, it it's like my 222... Send your email address and I'll see if I can get that scanned.
Doc
J.Neill
11-30-2006 15:15:14
 Re: Re: Case 210 mower engagement clutch in reply to Doc, 06-14-2003 06:24:30
I have a case 222 and can't get the clutch to disengage. Can any one help me out?
Bob Buri
06-30-2005 10:07:19
I just acquired a Case 220 yesterday. Without going into detail, The mower won't engage because the clutch assembly seems to be to loose. I think that the info you have may help me diagnos and repair the problem. I would appreciate it very much if I could obtain it. Thanks
motomax
05-06-2004 17:47:52
Doc,... If its not too much to ask,...Im in the same dilema,... Those scans would be a great help to me now.
Im not sure if the bearings where already fried , or I fried them from incorrect assembly,...now I know I need the bearings if anyone could point me in the right direction,....Thank You!
