Cub Cadet (1996)1863 Electric PTO
Tony
06-16-2003 10:03:35
I am on my 3rd electric PTO clutch. The first one lasted 5 years then the bearing froze up. The second one went through the 2002 season before the windings burned up. I replaced it in November. I now have maybe 12 hours on this 3rd clutch and the bearing is starting to rattle pretty bad. I stopped using the tractor before it locked up on me again. The shaft seems to spin ok with No noticeable wobble. Am I just having bad luck with clutches or is there something else wrong. I am thinking of getting rid of it. It only has 260 hours on it. Any help would be appprecaited.
Tony
MichaelFlu
08-27-2004 13:56:06
 Re: Cub Cadet (1996)1863 Electric PTO in reply to Tony, 06-16-2003 10:03:35
I have the same Cub....have replaced the PTO and switch 2 years ago, now the PTO is cutting out after running for just 10-30 minutes. Did you find a solution?
JimFMiller
10-16-2004 08:32:38
 Re: Cub Cadet (1996)1863 Electric PTO in reply to MichaelFlu, 08-27-2004 13:56:06
My 1863 PTO has been replaced about 2 years ago. Now after cutting for about 30 minutes it stops. I wait about an hour and can go another 30 minutes. I don"t know how to adjust. Do you know if the clutch may be slipping? If so, how can I adjust it?
Thanks,
Jim
