Changeing blades
tim
06-17-2003 06:42:00
hi i was just wondering if i could change my high lift blades to mulching blades.I know that the blade is what makes a mulching mower a mulching mower.The problem is I cant find any blades for my size deck.I find every size around it but cant find 40".So I was wondering if I could change them up because Im sick of racking up the grass when Im done mowing and the mulching would cut it in to little peaces so i wouldnt have to.I dont think it would cause a problem unless you guys would see one.let me know wut you think.
Ben in KY
06-18-2003 08:20:24
 Re: changeing blades in reply to tim, 06-17-2003 06:42:00
In addition to what the other posters have said. With a closed outlet chute for mulching quite a bit more HP is required when mulching. I have a 6hp self propelled mulcher. If I let the grass get too tall I have to open the chute and rake afterwards.
David
06-17-2003 20:30:02
It takes more than blades to change a mower to a mulcher, You must install some type of cover(kit) to close the opening and keep the grass under the mower deck, it also does require different blades, Mulching is a excellent idea but it does require more attention to mowing, must mow when dry to do a good job and should mow more often. Tall grass will just not chop up enough to disappear.
Ollie
06-17-2003 13:29:49
Measure each blade and replace with the like size.
lucas
06-17-2003 19:19:05
 Re: Re: changeing blades in reply to Ollie, 06-17-2003 13:29:49
well,,, i know guys that use gator blades like'em alot... but as they say.. you cant really mulch tall or wet grass well with anything..try'em,, its not an expensive experement... lucas
Ollie
06-18-2003 03:40:39
 Re: Re: Re: changeing blades in reply to lucas, 06-17-2003 19:19:05
I've been using Gatorblades for years. I have to cut tall wet grass and they do a fantastic job with it. Other so-called "mulching" blades are a joke but Gatorblades mulch anything.
Al m
06-20-2003 03:31:32
 Re: Re: Re: Re: changeing blades in reply to Ollie, 06-18-2003 03:40:39
just put gattors on my jd 300 last night.I am impressed with the thickness.Mowed about a half acre,seemed to do a good job.
Al
