Briggs 18HP Vanguard
Rod
06-24-2003 06:59:15
I have this engine on an Argo. Starts well but will no stabilize itself and constantly is reving up and down, and stalls when given additional throttle, and is impossible to get it to idle without stalling. Is this carburation or something to do with the governor?
MJM
06-24-2003 15:27:29
 Re: Briggs 18HP Vanguard in reply to Rod, 06-24-2003 06:59:15
Sounds like carb troubles. Check the carb for water in the gas. If so drain the tank, fuel lines and change the filter. Of course rebuild the carb. Then you should be good to go.
Good luck: MJM
