FORD 140 key switch
George
06-26-2003 18:40:32
I need to find a new key switch for a FORD 140 14hp tractor. Do you have one or know where I can get one.
Rick
06-27-2003 06:35:16
 Re: FORD 140 key switch in reply to George, 06-26-2003 18:40:32
NAPA has them. You must be sure of the type that you need before you buy. If your ignition system goes from the battery to the switch to a coil to the points you have a battery ignition. It's very common on older Kohler and Onan engines. The other type is magnito. On those when you turn the switch on no power flows from the switch to the engine except in the start then power goes to the relay or starter, but in the run mode there is NO power going out to the engine. You wil;l have a single wire coming out from under the engine shroud to the switch. When you turn the switch off it grounds out the magnito. The last time I got one I sent my son in law to pick it up with very clear instructions as to what he needed and the kid at NAPA told him that he didn't know what he was talking about and I had to go back and get the right one, so don't let them tell you there is onlt one.
