Cub 125 steering problems,(need help, the grass is
Andy
06-30-2003 13:26:01
My cub 125 will steer right but when I steer left the steering column backs out. Has this happened to anyone? is there an easy way to get at it that I'm missing? thanks, Andy
Andy
07-01-2003 19:18:17
 Re: cub 125 steering problems,(need help, the gras in reply to Andy, 06-30-2003 13:26:01
Thanks guys, I will need a new one, I cleaned the grease off the old one and it is split. It looks like a bugger to get at, any advise,(I tried swearing and it didn't help). thanks, Andy
Red Dave
07-01-2003 11:45:29
I got a rebuilt one from this outfit for my 123.
Lots cheaper than a new one from Cub Cadet.
Rick
06-30-2003 16:09:47
Your steering gear box is the problem. It is a worm gear type box. The housing is aluminum and has a set of ball bearings and races on top and bottom of the worm part of the shaft. The top race has ether worn away or broken and now the worm has been driven up through the boss cast into the housing. You can try to fix it but I would guess that at least you will need the housing (Tube and casting), the bearings and races. It’s a lot faster to find a used one (try Yahoo groups ihccubcadetractors) or get a whole new steering assembly from your local cub dealer. It’s not exactly like the original but is a direct bolt in replacement.
Hope this helps.
Rick
