Farmall Cub problem
Bob Strubbe
07-01-2003 17:42:24
I have a 1951 or 52 Farmall Cub that will not start. The tractor has good spark. It tends to flood and will not fire. It has been retimed and the rotor and carburetor has been replaced. Can anyone help me?
Rick
07-01-2003 18:40:36
 Re: Farmall Cub problem in reply to Bob Strubbe, 07-01-2003 17:42:24
You should try replacing the plugs. Just because a plug sparks in open air doesn't mean it will fire under the pressure in the combustion chamber.
If the timeing is correct and you have fuel air mixture and compression the only thing it could be is spark. It does have compression?
