Cub hydro
don
07-03-2003 13:10:57
can anyone tell me what could of happen to my 105. i was driving alond when all of a sudden the rear end locked up.try to push it the wheels just slide. thanks for any help you can give me don
Bob
07-04-2003 15:59:22
 Re: cub hydro in reply to don, 07-03-2003 13:10:57
You could have sheared a coupling or a key or a spirol pin in the shaft from the engine to the hydro. Not quite sure how yours is coupled up, but verify the the input shaft on the hydro is actually turning. There is a pin in the hydro charge pump that is known to shear. Does your tractor have hydraulic lift? Did I see in another post where it killed the engine when it locked up?Could you have lost the oil in the system and locked up the charge pump, or the main pump?
don
07-05-2003 14:47:31
 Re: Re: cub hydro in reply to Bob, 07-04-2003 15:59:22
that could be the problem. went back in about an hour and it started right up and i drove it in the shed. i just overhauled motor that much runs like a kitten. thanks for the info i'll look into that. no it doesn't have the lift.
don
07-05-2003 14:48:49
 Re: Re: Re: cub hydro in reply to don, 07-05-2003 14:47:31
Jim
07-03-2003 13:19:24
Don: Cant help with what happened, but suggest take a glance at ihcubcadet.com forum - lots of good info and knowledge out there. Jim
