Cub cadet 1250 battery won't charge.
Jim
07-06-2003 12:07:34
Battery won't charge and stops when I'm mowing grass after 20 minutes. Charge battery and it runs again for 20 - 30 minutes. Took volt reading when only the tractor was running, about 10.5 volts. Stop tractor and voltage goes up to 11.9 volts. When the mower deck is engaged the charging gage is way to the left indicating a battery discharge. Any ideas?
Dan
11-02-2003 12:49:49
 Re: cub cadet 1250 battery won't charge. in reply to Jim, 07-06-2003 12:07:34
I had the same problem with my Cub Cadet 1650, it turns out that the solution was in the ignition switch. I had repalced the ignition and the new switch was a 4-way switch (Off, Run + charge, Run + no charge, Start). After starting the engine, just turning the key one click to the left allowed the battery to charge. If you are running a replacement ignition switch this could be the problem, if not check the wiring to the switch.
I hope this helps.
-Dan
Ed Kent
09-15-2003 19:20:02
Have you had any luck on your charging problem. Our 1250 started doing the same thing. It will run longer than 20-30 minutes but battery is not charging.
Ed Kent
09-15-2003 19:15:00
Ollie
07-06-2003 16:27:39
The alternator/generator is not charging the battery. Verify cables and terminals are good, next step is a trip to the dealer to get the a/g replaced.
Rick
07-06-2003 15:03:35
Clean all of the battery connections first. If it still happens then you will need to get the trouble shooting guide for that engine.
