Bypassing the varidrive on a Sears GT14 Tractor
Harlyn
07-10-2003 08:27:22
Has anyone tried to bypass the varidrive system on a Sears tractor? I'm not able to locate varidrive parts for my GT14 and was thinking that maybe one long belt from the engine pulley to the transaxle might work.
Bob D.
07-10-2003 15:38:23
 Re: Bypassing the varidrive on a Sears GT14 Tracto in reply to Harlyn, 07-10-2003 08:27:22
Harlyn: If the longer belt fit, how would you regulate your speed? I have an older YTV varidrive 16hp...had similar problems in finding parts..but you might check with Ray's Mower Shop....Rt 73 Boyertown, Pa. 19512 610 367 2078..He has found anything I've asked for..e-mail RMS1050@aol.com...
Bob D. larriere@hotmail.com
Harlyn
07-10-2003 21:26:17
 Re: Re: Bypassing the varidrive on a Sears GT14 Tr in reply to Bob D., 07-10-2003 15:38:23
Ray's said they'd check and get back to me a few days ago. Haven't heard anything yet. With the longer belt and no varidrive, the only way to regulate the speed would be with the gears & throttle. I'm not sure if that would be workable. I'm hoping someone may have tried it and will let me know if it's practical.
Bob D.
07-11-2003 11:09:12
 Re: Re: Re: Bypassing the varidrive on a Sears GT1 in reply to Harlyn, 07-10-2003 21:26:17
Can see some difficulty in stopping, also...I have used different pulleys on the transaxle
but don't know anyone that has by passed the varidrive completely...Hopefully, Ray's will come through...
Bob
larry p.
07-31-2003 19:31:28
 Re: Re: Re: Re: Bypassing the varidrive on a Sears in reply to Bob D., 07-11-2003 11:09:12
i have a gt14 that a friend bypassed the vari-drive on, it seems to work ok. i coundn't get it to quit slipping the belts so we took it out.
james eldridge
09-30-2003 10:59:57
 Re: Re: Re: Re: Re: Bypassing the varidrive on a S in reply to larry p., 07-31-2003 19:31:28
I have the same problem. Acutually this system has been problematic from day one. The old wheel horse design sears was selling was much better. Anyhoo, this is my late father's tractor that I really only need to get up leaves with in the fall with the attatched e-z rake vacume. What size pulleys did you put on the variator shaft. Was one larger than the other? What kind of ratio resulted. How well are you able to regulate speed with just the 3 gears in the trans?
Thanks Jim
