Briggs 6HP- Smokes as Warms
Dan Pruitt
07-10-2003 17:30:03
Engine ran fine last week. Within a minute of stating it starts to smoke. I assume the smoke is excess oil in the cylinder area. I pulled the top of the cylinder head and I have a lot of oil/carbon build up on top of the piston and at the valves. Compression seems to be ok. I don't know if I have a piston ring problem or a valve sealing problem. Any tips would be appreciated.
Rick
07-11-2003 07:09:26
 Re: Briggs 6HP- Smokes as Warms in reply to Dan Pruitt, 07-10-2003 17:30:03
Sounds like your breather may be pluged. I would try that first. Then my next guess would be that your oil ring is stuck or worn. Keep in mind that compression is no indicator of oil ring problems and can actually incress compression due to bad oil ring because the oil helps seal the compression ring.
koontz
07-13-2003 09:34:35
 Re: Re: Briggs 6HP- Smokes as Warms in reply to Rick, 07-11-2003 07:09:26
did we sharpen the blades or have it on its side cleaning the under side???/ i myself would change the oil if it looks bad at all , park mower level or with piston slighty uphill..clean air filter also..
