16hp Brigs Twin Mod 402707 type 1212
Jim
07-11-2003 09:08:00
When cold will start and run for about 10 minutes, will not start until it cools down. Almost no spark when hot. ???
David
07-31-2003 02:08:17
 Re: 16hp Brigs Twin Mod 402707 type 1212 in reply to Jim, 07-11-2003 09:08:00
I have the same engine with a similar problem. Mine will run about 30 mins befor it quits. After it shuts down there will be no spark until it cools off . I replaced the coil but it still has the same problem. I am going to check the clearance between the coil and flywheel and if that is good I will check the flywheel key.
Jeff
05-26-2004 17:11:06
 Re: Re: 16hp Brigs Twin Mod 402707 type 1212 in reply to David, 07-31-2003 02:08:17
Did you ever solve the no spark problem. Mine ran about 20 minutes, now-no spark hot or cold.
