Flywheel Stuck
how do you remove
Karl
07-11-2003 18:35:52
OK, I'm probably getting into an area I don't belong, but here I go. B&S 12hp in a Whites mower. Engine had a solid hit noise and tractor stopped moving. Flywheel will not spin all they way around. Valves go in/out. trying to take apart motor to see why it stopped spinning. Any breakdown or steps in doing this is appreciated.
Thanks,
Karl
Ben in KY
07-14-2003 13:05:29
 Re: Flywheel Stuck - how do you remove in reply to Karl, 07-11-2003 18:35:52
Yep MAC is probably right. You need to take the other side of the engine apart, not the flywheel side.
Mac
07-11-2003 19:56:46
Sounds like you may have a broken rod. Take the oil sump/pan off and you should be able to tell.
koontz
07-13-2003 09:25:12
 Re: Re: Flywheel Stuck - how do you remove in reply to Mac, 07-11-2003 19:56:46
a puller,, don't have one:put nut back on top of crankshaft even with top of shaft, get big hammer & prybar. pick a good solid place to pry the bottom of flywheel, then smack the top of crankshaft(physics)
OR pry on oneside of the flywheel & smack the other side,this is not recomended but works good for me..
pull the head,see if piston is moving when turning flywheel
