Cub cadet 149
mike
07-13-2003 12:39:01
my 149 was setting for a time and the shift lever was froze, i finally freed it up and a day later i put it in to forward or reverse and it will not move. what can i do?
thanks,
mike
NCJohn
07-13-2003 14:11:13
 Re: cub cadet 149 in reply to mike, 07-13-2003 12:39:01
Try removing the cover in front of the seat and see if the linkage is actually moving when you move the lever. If it is, check to see if the two little buttons on top of the hydro unit are free and are not stuck down.
mike
07-15-2003 23:35:38
 Re: Re: cub cadet 149 in reply to NCJohn, 07-13-2003 14:11:13
i found the problem. the pin was sheared at the drive line connecting to the engine. then i decided to unfreeze the pins that release the tractor to push it and they got stuck in the down position. 3 hours later i was able to get to the pins with a rachet. labor of love.
