Cub Cadet 1715 w/17hp kohler mag has no spark
John Percoskie
07-15-2003 21:36:55
after the tractor runs for an hour or so it shuts off and I have no spark. I replaced the coil and it still did it so I returned the coil. after I let it sit for awile it fires back up. I checked the gap on the coil, jumpered the safty switches, replaced the ign. switch, starter sol. I need a few tips
Al Dziennik
06-21-2004 17:05:26
 Re: Cub Cadet 1715 w/17hp kohler mag has no spark in reply to John Percoskie, 07-15-2003 21:36:55
I had similar problem and after doing some of the same things you've already done, I found a short in the wiring. It was rubbing and shorted out the ignition current sometimes. I replaced all the wiring from back to front and placed in flexible tubing to prevent reocurrance. The one hour thing, though makes me think it's got to be something else possibly related to heat.
Glenn-WV
07-18-2003 10:31:33
Does that engine have a condenser? If so, it might be bad ...
John Percoskie
07-19-2003 18:04:47
 Re: Re: Cub Cadet 1715 w/17hp kohler mag has no sp in reply to Glenn-WV, 07-18-2003 10:31:33
nope no coil Glenn.
