Battery discharging while running
Jon
07-16-2003 07:16:46
have a cub 105 with a K-241. the meter shows a slight discharge while running and sure enough I ran it dead. Battery is good and took a charge. Any good ideas on chasing down the irregular voltage problem?
Thanks
Rick O
07-16-2003 19:51:14
 Re: battery discharging while running in reply to Jon, 07-16-2003 07:16:46
My 147 did the same thing. Upon investigation I found the wiring harness had given it's all. The wires had corroded and broke. The harness was in the worst condition where they were routed behind the battery. Check your wiring. With the age of your machine the problem may be the same. New factory harnesses are available and are easy to change out.
David
07-16-2003 08:15:44
Do you have electric clutch for mower engagement, if so it is possible that the cluch is shorted and drawing more than output. Check out as this would only happen when mower engaged. Try running for period of time with out clutch engaged. Good luck
