Briggs won't start !
Eric
07-17-2003 05:29:37
16 HP Twin Cylinder, turns over real well. I replaced plugs and still have no spark. I suspect the $50 ignition coil. Could it be something else that is prone to these engines that I am overlooking?
Eric
07-18-2003 06:00:03
 Re: Briggs won't start ! in reply to Eric, 07-17-2003 05:29:37
Thanks guys, Everything pointed to the coil, so I spent the money and it did fix this problem. I don't like when the box says no returns and you can't be positive it's going to fix the problem.
David
07-17-2003 17:41:45
unplug the kill switch wire from the coil check the air gap it should be .010 inch spin moter over and if it still doesent fire it is likely the coil
walt
07-17-2003 08:09:08
I would check the safety interlock switches.
MikeJ
07-19-2003 20:09:21
 Re: Re: Briggs won't start ! in reply to walt, 07-17-2003 08:09:08
has it got a low oil shutdown switch maybe it not working
